1992/engine service soon light
Old Oct 28, 2013 | 01:59 AM
godfather4's Avatar
godfather4
8th Gear
Default 1992/engine service soon light
how do I turn this light off , have reset the oil change light but this one keeps staying on
Old Oct 28, 2013 | 08:17 AM
vetteoz's Avatar
vetteoz
You don't.
The light indicates the computer has seen faults and has codes stored to show you what those faults are.
You are supposed to pull those codes so you know what is wrong
see
http://www.corvettephotographs.com/c4vettes/codes.htm
You can clear the codes by disconnecting the battery but if the problem is still present, the code will be recorded again and the light will come back on.
If the problem was intermittent or when you have fixed it, the light will stay off
Old Oct 28, 2013 | 08:49 AM
lt4obsesses's Avatar
lt4obsesses
Originally Posted by vetteoz
You don't.
see
Also, if it is intermittant, after a certain amount of test cycles, it will go off on it's own, but the code will be stored as a history code.
To 1992/engine service soon light
