Installing the LT1 hub
Old Jul 7, 2002 | 06:06 AM
R Cook 92's Avatar
R Cook 92
Default Installing the LT1 hub
I am ready to put the hub on the front of the crank, but I am wondering the best way to do this with out the special Kent moore tool. can the center bolt pull it on if I just turn the bolt until the hub bottoms out? Or what else is there? Theres gotta be a way!!!
ohhh yea, the arrow goes straight up when the motor is at TDC right? just want to make absolute sure here
Old Jul 8, 2002 | 12:30 AM
LT4PWRD's Avatar
LT4PWRD
Default Re: Installing the LT1 hub (R Cook 92)
I asked a similiar question about 3 weeks ago. Here is a link to that thread. I used a threaded rod to pull it on as suggested. Check out this post orif you search for "hub" in the archieves, you will find many suggestions. Hope this helps.
http://forums.corvetteforum.com/zerothread?id=320779
Chris - 1996 LT4
