Dana 44 gears
Guest
Posts: n/a
Dana 44 gears
This might be a dumb question but will any Dana 44 ring and pinion fit in the Corvette carrier? Or do the Corvettes take a special ring and pinion? Need to know what will fit my '87. I know the deep gears won't fit. I am looking for 3:54s or something in that range.
Received 1,401 Likes
Re: Dana 44 gears (topjimmy87)
a 4+3 comes with the D44 already, and you dont need 3.54s for a stock L98 engine, 3.07 is perfect
If you have an A4, a D44 will fit in there, but there are other things youll need to buy i think.
1 Post
St. Jude Contributor
What gear set is in the car now? Have you done any mods to the engine? What mods do you plan on doing in the future? You'll get alot of responses to this thread, alot of controversy on this mod. . . . . . . :smash: :smash: :smash: :smash:
Guest
Posts: n/a
Re: Dana 44 gears (edsalinas)
Stock gears, 52mm TPIS throttle body, cut lid, high flow cat and mufflers (mufflers are unknown origin but look like flowmasters). Otherwise, it is stock.
I've had musclecars before (but never a Corvette) and know what gears will do for performance. I am hoping a set of gears will do the same in my Corvette. I see a lot of gears on ebay and such but don't know what fits the Corvette. Does anyone know what fits??
Never mind. Answered my own question– jegs.com lists all the specs.
I'm open to all opinions. Thanks edsalinas.
[Modified by topjimmy87, 10:44 PM 7/8/2002]
Until you change the intake (miniram, superram, etc.) and/or dig into the motor (like 383, 396 conversion) you DO NOT need a lower gear in the L98.
You have 3.07s, its the perfect gear for L98s. You go lower and youll get out of your powerband way to fast. Anything you gain in the 1/8mi youll lose in the next 1/8mi and its very possible that a 1/4mi time will drop.
1 Post
You're welcome, don't know that I helped much, probably added to the confusion ! ! ! I guess it all depends on what you what to accomplish.
Daily driver with a bunch of R's off the line ? (Not too concerned with freeway drivin') . . . . A dragster at the 1/4 mile ? . . . . An autocrosser with "Umph"???? It's all relivent. That's what you need to decide, for yourself . . . . . . . I went with a Dana gear set (always the best choice) that allowed me a good punch off the line, but didn't prevent me from long distance freeway driving. After all,we're talking about my DAILY DRIVER. 3.59 put me there, I could have gone deeper, but I had all the right part numbers for the speedo-gear (automatic) and speed sender, etc, etc...... As I've said on this forum several times, get all the input you can from people in the KNOW, then decide what is best for you . . . . . . . . . . :cool:
P.S. as someone pointed out to me, the gear set I put in my '92 is 3.54, not 3.59. I humbly appologize :cheers:
[Modified by edsalinas, 1:51 PM 7/9/2002]
You can get 3.55s from almost any drive train vendor.
