where do these wires go
Old Dec 27, 2013 | 02:07 PM
wendal's Avatar
wendal
Default where do these wires go
I was wondering where this wires go? I only have 1 light for my shifter indicator.
Old Dec 27, 2013 | 03:41 PM
DanielRicany's Avatar
DanielRicany
I would imagine possibly the interlock actuator. I have a manual so I can't compare. It looks like there are two unconnected connectors. Can't say where the other one goes, you will need to look on the panel. I know the circular one to the right of the shifter is for your power outlet.
Old Dec 27, 2013 | 03:42 PM
DanielRicany
It actually look like that long one might go through the bracket where the power window switches are and go to something inside there. Maybe power mirrors, power seats, something like that?
Old Dec 27, 2013 | 03:52 PM
Sweede's Avatar
Sweede
I Think the large one is for the cigarette lighter
Old Dec 27, 2013 | 04:03 PM
vetteoz's Avatar
vetteoz
The interlock cable is as shown; connected to LH side of shifter
Old Dec 27, 2013 | 04:22 PM
wendal's Avatar
wendal
big white round goes to cigarette lighter.
Old Dec 28, 2013 | 04:01 AM
Cliff Harris's Avatar
Cliff Harris
There is only one bulb for the shift indicator.
I think they used the same light assembly on multiple cars and some had the bulb in the opposite end.
Old Dec 28, 2013 | 10:53 AM
adamzane's Avatar
adamzane
Neutral Safety Switch and Gear Selector indicator ???
Old Dec 28, 2013 | 11:44 AM
wendal's Avatar
wendal
I do not see anywhere for them to plug into. The car does have working backup lights.
Old Dec 28, 2013 | 12:04 PM
wendal's Avatar
wendal
I took side panels loose. the little short wire is hot and is hocked into the wires that go to the power drivers seat. Can does not have passenger power seat.
Long wire does not have any power
Old Dec 28, 2013 | 12:07 PM
wendal's Avatar
wendal
nope was wrong not hocked to power seat
Old Dec 28, 2013 | 12:30 PM
wendal's Avatar
wendal
my center console light does not work. put in a new bulb. not sure but the wires for it go to the front. How do you turn the console light on?
thanks
Old Dec 28, 2013 | 12:52 PM
Mtn Billy's Avatar
Mtn Billy
From the picture there isn't any O.D. switch next to the drivers window switch. could be for O.D.
Old Dec 28, 2013 | 01:22 PM
wendal's Avatar
wendal
I broke a tab off the light socket. So not it wont say in. Does anyone have a part number for it or a place to purchase one. Local parts store was a no go.
Old Jan 21, 2014 | 02:45 PM
wendal's Avatar
wendal
The long wire went to the seat belt. The short one goes into the back of the gear shifter. Not sure what is does. When the shifter in isn low it must do something.
Old Jan 22, 2014 | 05:28 AM
HlhnEast's Avatar
HlhnEast
Hatch release? Console glove box light? An FSM is a valuable tool for deciphering wire color codes.
Old Jan 22, 2014 | 05:55 AM
WVZR-1's Avatar
WVZR-1
I would start with an attempt with this socket GM 12007642 (LS64-ACD) would have been correct for the later C4 and I see no reason it wouldn't do the earlier, you won't find that one but I believe this one GM 12167138 (LS71-ACD) should be easily found. Take the earlier #'s and the later #'s both to a first rate auto parts store and you should be able to be helped maybe less expensively.
NAPA I believe certainly could, CARQUEST likely and most others I'd think also. I believe it would be on their shelf also. There should be no reason to have to order.
A GM dealer is likely or a larger ACD jobber.
I didn't say it "would" but it's likely and yours is broken so I'd say a start!
To where do these wires go
