Push vs Pull clutches fitting Flywheels
My question: Is there some dimensional difference between the flywheels between one for a push style pressure plate and a stock pull style pressure plate or are they the same?
Their bearing is the last one in this link. It's not anything "universal". I believe it's worth a conversation. Their support and shim packages are supplied if needed until it's correct.
http://www.mcleodracing.com/products...lt.asp?id=5188
Your discussions need to be with McLeod "before" ordering from anyone. You could put together most any weight flywheel that you would like.
I did an LSX 454 package for a fellow using their products and they didn't do the 9 bolt flywheel at the time but they were most helpful heading me towards someone that did the flywheel for us that at the time wasn't available. This was back early in '11. There's others that have used the McLeod 1345 either with the McLeod package OR after problems with a Ram or Howe product. Most were happy.
The 1345 isn't "inexpensive" BUT it's NOT universal either. Tailored to the application. True-fit stuff.
