Bad Injector?
Old Feb 28, 2014 | 08:38 PM
larryinalabama's Avatar
larryinalabama
If you have 2 different types of injectors the car has had a ongoing injector problem, my car had 3 different injectors, so I didn't even bother to ohm check them.
A Block Check kit will come with instruction, its fairly easy, the only way to goof up is to suck coolant, which wouldnt hurt anything
You may also want to check the fuel preshure.
I will say my problem got worse, and I wouldn't have figured it out except for reading the fuelinjector stickey. Injectors on most cars never go bad.
Old Apr 23, 2014 | 12:11 PM
C4.Taylor's Avatar
C4.Taylor
My start-up and stumbling problem has been solved. Cap and rotor. Was hell replacing the damn thing but I got the new one on there it it's running fine now. My fuel smell and white smoke has also stopped. Not really sure what I did to fix that. I replaced my coolant temperature sensor AND fuel pressure regulator so I'm guessing it was one of those. I still feel like I'm lacking some power so when I get a chance I'm going to check out my spark plugs to see what they look like. Thanks for all the help guys.
