NEW 92 Z07
Anyways, I need some advice, help. I picked up a 92 Black Rose/Black 6MT Coupe Z07 ($14.5k), all the options, sport seets, FX3 etc. etc.. The car has 31k miles on it and is in great shape. The previous owner installed a cat back flowmaster, new platinum plugs, TB Air Foil, Headers, Chip, K&N...He gave me a 52mm throttle body, MSD IGnition, 8mm Spark Plug Wires, adjustable fuel pressure regulator, 1.66mm Roller Rockers, for me to install later. The car pulls pretty hard now and I beleive it to be faster then my last vette (94 6MT, Stock)
Also, the passenger side seat does not move forward or back, and the Service Ride Control comes on and stays on....
I gues my questions are these:
1: What RWH do you think the car is running now?
2: What do you think it will run after I put the rest of the mods on? Will it keep up with a new LSI?
3: Any ideas on what to do about the Ride Control and Seat? Any idea how much it will cost and if it is even worth replacing and/or fixing? :D
Thanks for any help,
Greg
[Modified by 92Z07, 5:06 AM 7/19/2002]
[Modified by 92Z07, 5:14 AM 7/19/2002]
You should keep up with an early LS1.
You might want to do a search on the passenger seat too... I know I have seen posts regarding that too.
Check these guys out.... can give you an idea on costs for shocks too:
http://www.eshocks.com/bil_veh.asp?M...Long=Chevrolet
Good luck.
BTW... welcome to the forum.
When I bought my ZO7 2 days later the SRC light came on and that's all it was. The car has been very reliable since and I'm sure you'll find the same with yours.
Good Luck!! :cheers:
The Service Ride Control light will blink. Each digit is read by counting the number of flashes. Each code is two digits and each digit will have a one second gap between them. Each code will repeat 3 times.
More than one code may be displayed. Each code sequence will start with a code 12. Code 12 is just a start of sequence indicator.
Code Definitions
12 = Start of sequence
13 = Left rear time out
14 = Right Front time out
21 = Left Front time out
22 = Right Rear time out
31 = Left Front out of position
32 = Right Front out of position
33 = Left Rear out of position
34 = Right Rear out of position
Out of position codes are triggered if the computer senses that the actuator has not found the end stop position on the shock. Remove actuator at the indicated shock. Turn the valve gear on the shock stops after about 3 / 4 of turn, then you have a bad actuator. If it spins around continuously then it is a bad shock
41 = Selective ride control switch short to voltage
42 = Selective ride control switch open contacts
You can have a code 42 if you leave the switch in between indented positions
43 = selective ride control switch circuit open.
