What e.t. improvement from transgo kit only ?
Old Jul 22, 2002 | 03:54 PM
BLUE ONE's Avatar
BLUE ONE
Default What e.t. improvement from transgo kit only ?
Has anyone fitted a Transgo shift kit with no other mods AT THE SAME TIME and seen an improvement in their E.T. ? If so how much ?
I have a 90 coupe with B/M manifold, ASM runners, 1.6rr, zz4 cam, ported heads and manifolds and all the usual / little / free mods.
( drag radials and 3.07 gears )
I will be installing a GM 12" S10 converter soon and wanted to fit this kit only after i had the results from the converter.
Thanks Mark
:D :D :D
Old Jul 22, 2002 | 04:01 PM
vader86's Avatar
vader86
Default Re: What e.t. improvement from transgo kit only ? (BLUE ONE)
probably no gain in ET
Old Jul 22, 2002 | 04:48 PM
BLUE ONE's Avatar
BLUE ONE
Default Re: What e.t. improvement from transgo kit only ? (vader86)
Well...... you might be right as i have checked all the posts i can and no one has gone into print to say that it did :confused:
I know these kits improve the life of your trans but they do claim an improvement due to the fact the trans shifts quicker.
I was hoping somebody had done a before and after even if the result was no improvement. :sad: :nonod: :sad:
Old Jul 23, 2002 | 06:42 AM
93 ragtop's Avatar
93 ragtop
Im debating installing one as well. The question I wonder about is how hard on the rest of the drivetrain is a shift kit? IE: axles, dana 36 etc.
To What e.t. improvement from transgo kit only ?
