Need Alternator GURU---Help
Old 06-12-2014, 08:20 PM
  #41
T. Wayne Nelson
T. Wayne Nelson's Avatar
Originally Posted by WVZR-1
Halverson mentions 321- 368 for a 120 AMP, I see a '92 - '93 is 124 AMP 321-552 and a '93 - '96 140 AMP is a 321-1112. I'd maybe see which your local has and compare the clocking and remember you might need to swap pulley. Do you still have your old core? I like the idea of a used if it were an original and not someone's reman. Notice on the CF thread the mention of a rear brace. The connector swap and you would be in business I think. Study and let us know!!
So--purchase the 94 Alt and just change the connector, everything else bolts up including the brace from the exhaust bolts. These are dependable.
Old 06-12-2014, 08:28 PM
  #42
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
I've never done it personally on an '85 but I've done many changes through the years SI to CS and most were without issue. I'll try to check the clocking like I mention. The brace to the exhaust I'm unsure of but I'll check. An alternator brace/bracket is a simple fabrication in almost every situation. The CS144 is very reliable BUT you need to consider yours is likely coming off of a mass retailers shelf. That's why I mentioned used and look for an OE/GM. The warranty is "lifetime" anyway so it's only installation aggravation.
Old 06-12-2014, 08:36 PM
  #43
T. Wayne Nelson
Thanks to all who helped. I really learned a lot, and I am back up and running...As Usual the Corvette guys are the best....
Quick Reply: Need Alternator GURU---Help
