ac screeching
Jun 14, 2014 | 03:09 PM
ac screeching
I think it may be the clutch plate and or bearing. Anyone have any ideas how to check it and are the replacement parts hard to do yourself.
Jun 15, 2014 | 04:02 PM
Quote:
Originally Posted by
Cdn UFO
Buler Buler
Jun 16, 2014 | 12:37 AM
Sounds like the compressor is seized.
Take off the serpentine belt and try to turn the compressor by hand.
Jun 25, 2014 | 02:06 PM
Cdn UFO
Very simple to determine what the problem is : does it squeal all the time or only when you turn the AC on ?
For
most people the solution will be the same : take to garage and have compressor replaced and system recharged.
Mechanically competent person
may luck in and not have to replace entire compressor assy.
Jun 25, 2014 | 04:14 PM
it depends on the year on what parts you can get. I had a hard time finding a clutch for my 88. It has been awhile but I do not think I found one and went with a complete compressor. And I have a lot of resources. I also belive the compressor was higher then most
Jun 25, 2014 | 04:27 PM
hooked073
The ones I worked on I could replace the clutch bearing.
Jun 25, 2014 | 04:36 PM
That is possible if the rest of the clutch is not trashed.
Jun 25, 2014 | 04:50 PM
hooked073
Whatever, majority of the time help requests on here are just moot conversations anyway .................
