Fuel pressure tester needle flutters violently?
Hi guys, I have a 1985 Corvette with a Miniram, 58mm throttle body, AFR 195 Eliminator Heads, flat tappet ZZ409 cam, Hedman longtube 1 5/8" headers, Dynomax true dual 2 1/4" exhaust, 1.6 Comp cam roller rockers, D.U.I. distributor, MSD 6AL2 ignition box, Descreened MAF sensor, no cats, and a few other mods.
My fuel pressure is supposed to be at 60, because I am running 24 lb injectors and need it for the injectors to keep up. Me and my tuner have been tuning off of 60. Anyway, when I connect the fuel pressure gauge, the needle flutters violently. This happened with the old gauge I had to, but I always thought that was just because the old gauge had a small leak. It jumps back and for from like 55 - 65 PSI. I don't think it does it on other cars either.
Does anyone know what could be wrong? I wanted to hook it up to see if fuel pressure drops off at high RPMs to see if I had an insufficient pump, but now I can't even set the fuel pressure accurately.
Thanks!
Thanks!
Thanks!
Thanks!
No, that won't work. I thought your goal was to see if your pump is undersized. I thought we had the conversation that you could find out by data logging at WOT and then looking at O2 voltage.
It is. But I had some problems getting the car started yesterday after getting the trans in, and I had played around with the fuel pressure to see if maybe there was air in the fuel lines, to try to bleed it out. I had spark, fuel pressure, injector pulse, and timing set properly and it wasn't starting. Started up on starting fluid. Turns out the gas went bad after only 2 months. Drained it out and put fresh gas in and it fired right up. But since I messed with the FPR I'm trying to set fuel pressure again.
Pro Mechanic
Pro Mechanic
Really. And where is that point, in your fuel system? How does it do that when it's being circulated (pushed through the system) at a fairly high velocity?
And even if air were trapped in the "highest point"...who cares? What's it going to hurt? How? Think.
EDIT: My point is, once again, you're chasing your tail trying to resolve problems that don't matter, don't exist or both. The goal was to test your fuel pressure. Test your fuel pressure.
Pro Mechanic
Chasing "problems" that don't exist.
Especially for the fact that it was just running the same day for about 10 seconds until it shut off.
In any case, the flutter is not causing operability problems. When adjusting the fuel pressure just adjust for the middle of the needle swings.
Pro Mechanic
