WTK: location of secondary cooling fan temp switch
My secondary cooling fan (in front of radiatior) has decided to quit working. I know there is a temperature switch that controls this fan, but I don't know exactly where it is located. There is a sensor on the driver side of the engine block that has a single wire coming off of it that has been almost burnt in half after accidentally falling against the header - not sure if that's the one though.
TIA for the help :)
TIA for the help :)
Re: WTK: location of secondary cooling fan temp switch (ROME)
The factory switch is between the 1 & 3 spark plugs on the eninge block. Im pretty sure what you burnt was the switch.
Cruise-In II Veteran
That's the aux fan sensor. You can just splice a section of wire into that one.
To verify all else is fine, turn the key On and touch the end of the wire to ground. That should bring On the aux fan.
