Timing Help on 383 LT4
Any thoughts?
Is it possible my tip in stumble is more or less because the car doesn't like stoich at anything under 2000 RPM? At this point, its all light throttle so I am not entering PE.
What inj, Duty cycle, LT & ST counts, 02 mV, knock count?
for my custom grind 236/ 244 .580/.580 110 CL 11.5 static
your Main Spark table 400 - 800 smooth around 20.5 Kpa
Main Spark Table 1800 RPM should be about
65 Kpa 38 Deg 70 Kpa 36 Deg 75 Kpa 34 Deg
closed TPS i have 20 Deg 400 RPM 22 Deg 800 RPM 24 Deg 1200 RPM 28 Deg 1600 RPM 32 Deg 2000 RPM.
most of your tune will be in the VE table tweak in the MAF table.
Have you matched your inj in your constants table.
Most importantly what definition are you using EE or EEb
Look at your constants table do you have crazy readings for your cylinder volume & inj flow rate. Like mine @ 47 lbs EEb vs 59.51 in EE If you do your using the wrong definition and will be nearly impossible to tune!!
Great tip zeroing out the % Change RPM @ WOT
Math calculate the % change cool temp @ WOT example 44 Deg C 15.6 % Change 56 - 104 Deg C 14.5 % Change GM's calculation is way rich for protection.
You should re calculate the Open loop AFR vs cool temp as well again very rich
A wide band is a great tune saver. Dyno even better.
Any thoughts?
I would assume the stumble is a lean tip in. You should add more accelerator enrichment and see if the stumble goes away. If you has a WB sensor you could watch it at the stumble and see if the AFR goes lean. Short runner intakes are touchy on tip in throttle and usually require some tuning in this area after modification are performed to eliminate the stumble.
