Big Doggie mod done - what I learned
Sadly, the only instructions for this are in a poorly scanned PDF from 1992. There are a few things in that article that aren't clear.
Aside from that I have to say this is a really cool mod. I really like the sawblades and really wanted to keep a stealthy, stock look at first glance but have always wanted the big 315's on the rear. This mod was the key to getting that done. It wasn't cheap, but it's the clean way to get it done.
Also, a green pad and some Fast Orange go a long way towards cleaning up the aluminum suspension parts.
- The biggest of these is the "relieving" that must be done to the knuckles. Yes, you can do it free-hand as the article states but you'd better be strong to hold a high speed grinder in place and not end up making a really ugly cut. I'm not, so both of mine are ugly. Since it will only be seen when torn down it doesn't really matter, but still - if you can pull the knuckles and machine them it would be much cleaner. Doing that would require some sort of jig for a lathe though, so free-hand might be the cheaper way. The easiest way to make that cut is to use a magic marker in the face that the back side of the wheel bearing contacts. Then snap the caliper adapter in place and use it as a guide to center the wheel bearing. You'll see there is a gap of at least .135" between the bearing and the caliper adapter. Press the bearing inwards while rotating it to make a scribe mark in the marker - you now know how much material to remove. In my case it was close to 1/4" and I went .150" deep to allow for uneven cutting and/or expansion.
- Cutting the caliper adapter - what the article doesn't tell you. There is a chamfer on the back side of the adapter that is REQUIRED. Without that chamfer the adapter won't fit flush with the knuckle. There is a very small radius at the base of the raised "tower" that the adapter fits over, so you'll need to make sure your machinist cuts that chamfer when they make the other 2 cuts on the adapter.
- The bolt for the upper trailing arm (on the knuckle) will now be too long to be able to be removed once everything is assembled, so you'll need to insert it through from the inside of the car pointing outside instead. You'll also need and extra washer for the nut - I found that a spare washer from a front brake caliper adapter bolt fit perfectly. The small OD is just right.
- Interestingly, the cotter pin holes in the early axle stub are smaller (1/8") than the later stubs (3/16") so you'll need different cotter pins for those.
HoracioL98 (11-14-2020)
Not yet. I should have taken pics while doing the work, but didn't. I do have before pics of the wheels and how much they hung out, so I'll get after pics today or tomorrow.
Today is injector swap and right side header install day.
Macaroni Kid (01-13-2023)
hi there. I'm not familiar with this mod. So does it just enable you to tuck the tire more under the car? I also have a 92 but I already run a 335 rear tire. I'm the 3rd owner, so I'm not sure if this type of thing has already been done.
This allows for fitting stock ZR-1 offset wheels under 88-96 cars without using flares. If you're going to fit 335's I would expect you'd be using custom wheels so you wouldn't need this.
Effectively, this narrows the rear end .543" on each side so slightly over 1" overall.
HoracioL98 (11-19-2020)
Off Topic
For those of you too young to remember the Big Doggie mod:
http://aurora40.dyndns.org/misc/C4%2...%20rearend.pdf
Denis
Yes you're probably right. I found it on the Net some years ago. Another of your Australian vette buddies ID'd as someone he knew (you). I thought it was pretty cool shot.
HoracioL98 (11-15-2020)
Apparently a lot of guys want this PDF. I'm happy to send it out, but I want to make sure everyone understands that is ONLY done to fit OEM C4 ZR-1 offset wheels under the back of 88 and later C4's - the 84 to 87's can fit them without mods as I understand.
I paid $500 (cheap these days) for the rear wheels, plus another $700+ in parts and machining, plus did all the work myself. It would be smarter to just order a set of Centerline Billet wheels with the correct offset and be done with it. Unless you're trying to keep it all stock-appearing that is.
Anyways, I'm happy to e-mail the PDF to anyone who needs it.
Also, rather than having those spacers machined for the 6 bolts, I’d just thread a die down each one, cut off .300” and clean up the threads. Much simpler. And, if you can machine the knuckle for your bearing on a mill you’re WAY better off. Doing it freehand works, but it’s messy and you’ll never get a nice clean cut.
SECOND THOUGHT on the bolt cutting - I think there is a shank on the bolts that prevents this from being done, so double check that.
The following 3 users liked this post by mcm95403:
