Dana 36 to Dana 44 Swap
Is the Dana 44 a direct replacement for a Dana 36? I'm building a '60 Project car that will use an '86 suspension and I'd like to upgrade to the Dana 44 but, would like to use the '86 suspension.
So can I take and directly bolt in the Dana 44 batwing and have the remaining suspension pieces from the '86 fit right up?
Re: Dana 36 to Dana 44 Swap (kahuner)
It's the same in every regard for parts bolting up with the exception that the "nose" on the Dana 44 is a little longer, so the driveline support beam and the drive shaft are a little bit shorter than those used with the Dana 36.
