Gas Tank Pressure and Stumble?
Have a Stumble on take off from a stop...
Sometimes it stalls, but it starts right back up no problem.
More times it happens on an easy gas start, doesn't happen when I take off fast.
New Fuel pump, filter, plugs, cap, rotor, IAC valve, air filter.
Whenever I Open the Gas Cap, the sound of Air sucking back into the tank is very evident.
Could that be causing the fuel pump to have a hard time getting gas?
1991 Coupe.
AT.
1991 Coupe.
AT.
Hesitation, sag and stumble is defined and outlined in the Factory Service Manual in detail.
Do you have a scanner????
Do you know what the TPS is reading when you turn the key on????
How does it idle???? Did you verify fuel pressure????
Did you possible replace the Oxygen sensor and forget to write that you had????
Possible vacuum leaks.
What type of fuel cap do you have???? It should be the design that allows air to be drawn into the tank and not one that seals up the fuel tank. Maybe drive it (carefully)with the cap loose and see if that changes things...but doubtful. because you did not write if it happens when you first crank the engine...when it is still in OPEN LOOP and the engine is cold and then the problem starts to develop.
DUB
DUB
You shouldn't have vacuum in the tank. It's much more likely to be pressure. The fuel gets hotter and hotter as you drive because it picks up heat in the fuel rails and then gets recirculated back to the tank. That causes the pressure to go up. There was a thread a while ago on this...
http://forums.corvetteforum.com/c4-t...nk-normal.html
You might have a problem with the charcoal canister and its connections.
Replace the Charcoal canister located in the rear passenger side wheel well and also, the Vapor canister Purge valve, located in the same location.
I AGREE...and I have seen charcoal material get sucked up into the hose by the valve cover.
Hopefully your local dealer actually has a tech that KNOWS the Corvette. I SERIOUSLY DOUBT that it is an EGR valve....because your idle is fine....as you stated.
AND...TRUST ME....you do not want some 'monkey' messing around with tubed runners and plenum if it NOT required. I repair so many Tuned Port engines due to the previous 'monkey' got in there and hit all the surfaces of the aluminum with a brisket pad and damaged the surfaces....then...they torqued the bolts WAY MORE than required......because the 'monkey' can not take time to read a service manual because he is in such a hurry to make BUCK.....and this action created MORE vacuum leaks than should be legally allowed.
BEST of luck to you.
DUB
