First Fuel Injection L98 manifold
#41
First Manifold Intake
......... I ran one of the FIRST intakes on a 409" engine ... it performed well up to about 5800 rpm then the engine size overcame the long runners ... the runners are 1 3/4" in diameter and can be ported to 1.900" ... stock TPI is about 1 1/2" diameter ... they offer a milled down throttle body top for hood clearance for the C4 and also have a larger TB as an upgrade ... the TB is included in the price making it a very good value ... on the negative side , the runners openings were a bit out of shape and it took a lot of time to get them gasket matched ... when you think about it , there are 40 holes to match up to gaskets ... I eventually replaced the FIRST with a single plane intake ... because I like to drag race and always need to go faster ........
