Software recommendation please
Old Jan 17, 2015 | 02:57 AM
puzzigully's Avatar
puzzigully
Default Software recommendation please
Guys,
I have ordered the moates cable etc for my 1987 corvette.
Some may have followed my problems trying to resolve an error 36, MAF burn off error code.
I need to know what the ECM is seeing once I switch off the engine.
Which software in your opinions will make it easiest to see the data coming from the MAF after engine shut down?
Obviously it needs to have the facility to keep logging data AFTER the engine is shut down.
All advice welcomed.
At present I'm looking at Datamaster, but no real knowledge as to why....I don't need to make changes to the ECM, right now
Old Jan 19, 2015 | 09:48 AM
MrWillys's Avatar
MrWillys
No data will be collected once the ecm is turned off from any software. Datamaster is the most user friendly.
Here's a flowchart for error code 36.
http://www.chevythunder.com/maf_code_36.htm
Old Jan 19, 2015 | 05:03 PM
puzzigully's Avatar
puzzigully
Thanks,
There's a thread in Tech section that I've been posting to.
Everything checks out in the flowchart and I've seen the burn off occur, thus I need to verify that the signal getting to the ECM is within the range it expects - as it appears that this is the only reason the code 36 is being set.
I understand the ECM does not turn off, when you turn off the engine, so its still collecting data.
I need to see what the burn off data is being sent the ECM so I can understand whats going on.
I imagine Datamaster allows you to turn off/on data collection?
Old Jan 19, 2015 | 06:00 PM
MrWillys's Avatar
MrWillys
While the burn off relay gets constant power from pin B1 at all times the ALDL does not report in key off. Therefore, logging software is lost in key off.
Old Jan 20, 2015 | 12:07 AM
Cliff Harris's Avatar
Cliff Harris
From what I've seen (as posted in the other thread), the ECM stays alive about 11 seconds after ignition-off. That time might be shorter if the ECM is in open loop mode because it doesn't do the MAF burnoff. I'm pretty sure it still resets the IAC, though.
As far as I know the data coming out of the ALDL port stops immediately. My laptop is in the car and connected to the ALDL port, so I can test that...
Datalog during ignition off, engine running (non-essential stuff edited out -- I stopped logging before the ECM turned off):
Code:
RPM	AIR_FLOW	BATT_VOLT	FP_RLY_VLT
850	10	13.7	13.9
1000	10	13.7	13.9
1000	9	0.0	13.0
0	8	0.0	12.7
0	6	0.0	12.6
0	5	0.0	12.6
0	4	0.1	12.6
0	4	0.0	12.6
0	4	0.0	12.5
0	3	0.0	12.5
0	3	0.0	12.5
0	3	0.1	12.5
0	2	0.0	12.5
0	2	0.1	12.4
0	0	0.1	12.3
0	0	0.0	12.3
0	0	0.0	12.1
0	59	0.0	1.1
0	59	0.0	0.1
0	59	0.0	0.0
0	59	0.0	0.0
0	59	0.0	0.0
0	59	0.0	0.0
0	59	0.0	0.0
0	59	0.0	0.0
0	59	0.0	0.0
0	59	0.0	0.0
0	59	0.0	0.0
0	59	0.0	0.0
We see the RPM drop to zero and the BATT_VOLT also goes to zero. This is the voltage from the ignition switch. The AIR_FLOW (MAF output in grams/second) drops off until the MAF power relay de-energizes. Then it jumps up to 59 gm/sec, which is caused by the ECM pullup resistor. Since the fuel pump relay supplies power to the MAF power relay, it's voltage goes to zero as the MAF gets turned off.
We see by this that the ECM DOES put out data after the ignition is turned off.
We have to go into the ECM program code to find out the relationship between MAF output voltage and air flow. It's a series of tables with various scalars, but here is the table where our 59 gm/sec comes from:
Code:
      ; Mass Air Flow TABLE 3
      ; TABLE =  gm/sec * 3.08
LC6B3:  FCB 83    ; TABLE SCALAR
LC6B4:  FCB 8     ; 9 LINE TBL
                        ;    gm/sec    BIN      VDC     lb/hr
         FCB        147 ;    47.7      768     2.19      368
         FCB        158 ;    51.2      800     2.29      395
         FCB        170 ;    55.1      832     2.38      425
         FCB        182 ;    59.0      864     2.47      455
         FCB        195 ;    63.2      896     2.56      488
         FCB        209 ;    67.8      928     2.65      523
         FCB        223 ;    72.3      960     2.74      558
         FCB        238 ;    77.2      992     2.83      596
         FCB        253 ;    82.0     1024     2.93      633
So 59 gm/sec comes from a MAF voltage of 2.47 volts, which is what my oscilloscope trace showed in the post in the other thread.
I only ran the engine for a few seconds, so it never went into closed loop mode and therefore did not do a MAF burnoff. I'll try to capture a MAF burnoff tomorrow.
Old Jan 20, 2015 | 04:52 PM
puzzigully's Avatar
puzzigully
Cliff,
thanks for the info...
When i get to the bottom of the error code and fix it, I'm coming over there and buying you a beer!
Would love to see the data showing the burn-off taking place as this is what I will be looking for once the cable arrives.
Cant wait to see what it looks like.
What software are you using?
What is the time period between data points as shown?
Old Jan 20, 2015 | 11:41 PM
Cliff Harris
I don't like beer and never drink it. I do like root beer, though...
I did make several burnoff runs today and here is one of them (highly edited to eliminate all the extraneous stuff):
Code:
AIR_FLOW	FRAME_NUM
56	3720
101	3721
64	3722
26	3723
25	3724
25	3725
25	3726
25	3727
25	3728
25	3729
25	3730
55	3731
There were a bunch of 55/56 air flow rates before and after the dip during the burnoff period.
Using the data section of the ECM program code (edited for length):
Code:
         FCB        119 ;    22.3      512     1.46      172
         FCB        133 ;    25.0      544     1.55      193
         FCB        147 ;    27.6      576     1.65      213
The air flow rate of 25 grams/sec comes out to 1.55 volts, which is within the error code 36 limits, so it passes the test.
I use Diacom+. I bought it in 2000 for $585. It is no longer available. It requires a hardware parallel port and runs in DOS, so it won't work on newer computers.
Diacom logs at 8192 baud which gives a frame rate of about 10 records per second, or roughly 1/10 of a second per frame. There are 63 pieces of data in a frame/record plus some other bytes for checksum and identification.
Old Jan 21, 2015 | 09:20 PM
puzzigully's Avatar
puzzigully
My Moates cable arrived today and have downloaded the DATAMASTER software.
Will be giving it a go this weekend.
The setup looks simple enough...just need to work out how to correctly start/stop the data logging so I can see what I need to see...
Fingers crossed!
Old Jan 23, 2015 | 08:19 PM
puzzigully's Avatar
puzzigully
I got the Moates cable and data logger software working.
Was sooooo easy
Did a run, saw that it was in closed loop (software tells you, very convenient)
Turned off the engine, watched the burn off take place, then stopped the data collection.
Looked at the data, doesn't look like the ECM saw it happen??
I checked the resistance from the maf to the ECM..... It was 0.1 ohms...so fine...
Post up the data later, but now at least I know the burn off is happening, it's just the ECM isn't seeing it....
Actually really like the data logger software
While I was pulling the ECM, if found a vacuum connector that was loose - plugged that back in and now have vent control!!!!!!!
At least I fixed something!!!!!
Just overheating and the code 36 to fix now (and a small oil weep)
To Software recommendation please
