Crazy starting problem
Old Jan 20, 2015 | 12:04 PM
texasduke's Avatar
texasduke
8th Gear
Default Crazy starting problem
1988 Corvette manual transmission..
went out started fine.. ran for a little while.. turned off the key.. went to start again.. NOTHING.. no starter turn.. and not a light on the dash or anywhere.. has done this now 3 different times.. battery is fine charged up.. usually will start again in a few hours.. but not always.. HELP..
Old Jan 20, 2015 | 12:21 PM
John A. Marker's Avatar
John A. Marker
Start by removing the negative cable from the battery and then the positive. Clean all battery and cable surfaces.
After that possibly a VATS problem. Check for any stored codes. Check for the codes before removing the battery cables.......
Old Jan 20, 2015 | 08:24 PM
jv9999's Avatar
jv9999
When this happens do your interior lights work?
To Crazy starting problem
