Warm or cold
Old Feb 16, 2015 | 01:35 AM
mlm0's Avatar
mlm0
Default Warm or cold
When setting min idle rpm, does it matter if engine is at operating temp first?
Old Feb 16, 2015 | 01:44 AM
DanielRicany's Avatar
DanielRicany
Yes. Some of the ECU's retard timing when cold which could affect this procedure. Also an engine runs optimally when hot. You may not even be able to keep the engine alive during this procedure when cold.
Old Feb 16, 2015 | 08:07 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Yes, it's always advisable to make any engine adjustments after complete warm up.
Old Feb 16, 2015 | 10:59 AM
mlm0's Avatar
mlm0
Thanks guys
Old Feb 16, 2015 | 11:00 AM
vader86's Avatar
vader86
Do it when warm, even if you're having cold/startup idle issues.
To Warm or cold
