1989 C68 HVAC No heat no A/C
the electronic control unit appears to be working. It lights up, I can control the blower manually (it does flicker when I hold the button down) it shows outside air temp and desired temp, checked for codes and none present. the blower comes on, the vent dampers don't move, no heat in winter, no A/C (compressor doesn't engage) I have the FSM but not sure where to start trouble shooting.
I did find a blown fuse for the A/C and replaced it. I do have vacuum (17in) at the ball and the ball does hold a vacuum. I have thought about just sending the head unit off to be rebuilt (since there is the flicker) but I don't want to do that with every part of the system. Since the head unit controls everything, I thought that may be a good place to start. Any suggestions on where to start would be appreciated.
The A/C fuse is for the compressor only.
Most of the A/C functions are performed by the HVAC programmer, which is attached to a bracket on the inside of the firewall above the gas pedal. Vacuum controls the movement of the HVAC air, so the first thing to check is that vacuum is getting to the HVAC programmer (black plastic tubing).
This article might be good background information:
https://www.corvetteforum.com/forums...schematic.html
checking the programmer.
voltage at clutch
I checked the voltage at the clutch, 3 volts and at blower control C1 and it also was 3 volts. At one of the pressure switches on ac line it was 12. Also the new fuse I put in for A/C blew.
The voltage from the A/C fuse should be 12 volts. The compressor clutch is engaged by applying ground to the other wire. This diagram is for my '86 and I know there was a relay added a year or two later to control the compressor clutch, but this wiring diagram shows the general layout:
During this ordeal I have been corresponding with Paul Koerner as well. I sent him the same findings as I posted here and this was his response : Your voltages are acceptable, however, your command from the HVAC control head is not accurate. You will most likely need a control head
