1986 all of a sudden started to flood out. HELP
OK, drove it about 20 miles, parked it for about 8 hours, and it wouldn't start. To make a long story short, it was flooded out, badly. Here is what I have so far.
Fuel pressure at 32 PSI and not draining.
Changed out the coolant temp sensor.
Fuel pressure regulator OK.
I do get the service engine light on when on the highway. Code 32 EGR. Reset.
12V at injectors.
Pull the FR fuse and can get it to start and idle after clearing the flood. Install the fuse again and it floods out. One time it did run pretty good, but just floods it back up. Acts like the injectors are just open.
This car has never given me any trouble, 47,000 original miles.
Any help would be appreciated.
12V at injectors.
I don't have a noid light, but I put a test light on and one side it is on, also 12V the other side not. With the test light on the side with no light and starting the car should it blink for pulsating? I put it on the 12V side and it didn't blink there either. Wondering if this would even cause the flooding?
Check the fuel pressure regulator for fuel in the vacuum line.
If the FPR diaphragm is ruptured it will send fuel into the plenum and it will run very rich.
Had the test light on ground and one side of the injector terminal and it stayed light, no pulse.
Had the test light on battery positive side, and negative side of terminal, lite up, no pulse.
So this is telling me the injectors are wide open at all times
What controls that? The ECM, or a ground wire. Now I did check both sides, same result.
This makes a little sense since the car will idle with the FR fuse removed and the fuel pump not running.
Well here that went.
Well with the key on, I checked at the ECM and both the green and blue wires and only get 1.0V should be 12 according to my service manual with the key on.
I get good resistance at all the injectors. My service manual says ECM. Does this seem right with how the ECM tested, or could there be a short somewhere causing the ecm not to test ok.
Looks at the wiring diagram, the blue & green wires are grounded on & off by the ecm. They're not going to have 12v. The other side should. Its easier to use a noid light. The injector works like a bulb.
I'll have to get a noid light, but I do know the injectors cannot be pulsating. While running, I used a long screw driver and I do not hear any clicking from the injector either.
So if the noid light shows no pulsating, then it is back to the ECM?
I checked over the harness and it looks good.
My 02 sensor wire looks rough, but no codes.
As I wait to get a noid tester, and other things I should look at?
Thanks, I really really appreciate your help.
I wonder if there is a short to ground between the injector connectors & the ecm.
Yeah, you should hear the injectors clicking when its running. Ideally you'd want to scan it for weird data before condemning the ecm.
Maybe try ohming the injectors.
I'll check again the harness, but it looked good.
So to check for the short, trace the wiring from each injector to the firewall basically.
Pulled the ecm and apart, nothing visually wrong.
