87 Running Rich
87 Running Rich
O2 reads in the 800-900+ mV range pretty consistently. It occasionally sets a Code 45.
I’ve replaced the IAC and the O2 sensor, checked for vacuum leaks, tried disconnecting (and plugging) the lines from the EVAP, disconnected (and plugged) the tubes in the A.I.R. system. Nothing has made any difference.
Any ideas about the most likely culprit?
It started running rich at idle a few years ago (discovered in emissions test) and has just gotten progressively worse.
Thanks for the ideas. I checked the fuel pressure and it's running about 40 PSI. I pulled the vacuum hose off the regulator and it's dry.
Is there a way to see if an injector is leaking without removing the injector?
Another thing that will cause a rich condition is a misfiring cylinder. How old are the plugs and wires?
It holds pressure for a few minutes and was at 20 PSI after 15 minutes.
I *thought* I had replaced the wires when I replaced the plugs, cap and rotor (3 yrs ago), but I may not have. In that case, the wires may be over 10 yrs old.
A while back, I pulled a couple of plugs (#5 and #7) and found both to be pretty fouled with black soot. I'm thinking maybe all of them are fouled, rather than just a single cylinder misfiring.
It is common to cross the plug wires for #5 and #7. That will cause the plugs to fire at the wrong time and those cylinders will be dead. I suggest pulling all the plugs to see what's really happening.
