Burning electrical smell coming from behind the batter on my 86
Hey gang;
I guess it's always going to be something with these old cars. Electrical stuff isn't really my forte, but I do like to givie it a shot. So, when I rutn on my AC, I've been smelling this electrical burning smell. I popped the hood, fired up the engine, turned on the AC and noticed the smell is coming from behind the batter. There are 2 relays back there and a bunch of wires that terminate on a golt. The wires that terminate on that bolt are hot. If i touch the bolt, it's really hot. I thought it was a ground, but when I checked it with the power probe, it's reading +12 volts. Whatever that thing is, it gets really really hot and only is energized when I turn on my AC.
Anyone know what all that stuff is behind the battery? I'm guessing whatever it is, the thing with all the wires bolted to it, it's failing.
thanks gang.
Bob
thanks gang.
Bob
The relays are the MAF power and MAF burnoff relays.
The junction is the "jump start block" (stupid name in my opinion, as you would never use it for jump starting the engine). There are a bunch of fusible links there that supply power to various things that require high current, like the headlights. The output from the alternator also connects there.
Thanks much.
Fix this. Mine was loose because the post corroded. The car would definitely have burned up.
something definately aint right
curious, did you get an electical burning smell?
Man I hate electrical stuff. It's never easy
Bob
Problem Solved!!
So I pulled the battery out, went to loosen the nut on the jump start block and the damn thing was just about finger tight. Took all the wires off, cleaned them up, hit the connections with a bit of di electric grease, reassembled the whole mess and wha la. no more burning smell. And, I swear the damn thing is idling better with the AC on. who knows what other problems I was having or was about to have with that thing. I'm no electritian, but this sure seems like a goofy way to do a junction.
Anyway, thanks all for helping my identify this and fix it. good confidence booster for when I have to tackle that heater core.
Bob
Bob
