tuner cat is better then a scan tool?
i've readed some times here on forum, many of you have a scan tool...
I would purchase TUNER CAT, anyone has this software?
would ask you what's its purpose, if it makes everthing that a scan tool makes, and seems that it is better than a scan tool, cause i've understand that i can reprogram ECM
thx
chris
thx
chris
thx
chris
thx
chris
you can also use the ST / LT auto find feature. To find where your AFR needs correcting. Then use CATS to Program.
I like CATS better then tuner PRO.
Datamaster is what you are looking for. you can data log. Record a 1/4 pull. There is a ET/Trap feature. Record from 2K - WOT and there is a DYNO feature. it also scans your trouble codes with a description.
Did you mean datamaster from here?
http://www.tunercat.com
When i said " tunercat " i meant LT1 TUNING KIT PRO from they, that contains even datamaster
You too?
CATS merged. And now they carry a complete line.
So yes, in there full combo kit. You get CATS tune, datamaster log,
A OBD1 & OBD2 y to USB cable. Depending on 92-93 LT1'
You still have A EEprom to de-solder.. purchase a burner and the CATS specific STS series EEproms. Or 94 - 95 LT1's CATS tune program staight to the Flash inside the PCM. One downside. If your programming is interrupted for any reason and stops. 1st stage erases the flash. Now you are in huge trouble. The flash is un-usable. The PCM would need to be taken apart. De-solder 2 flash chips. They are almost impossible to purchase.. Flash them with another programer with a base. To re-flash with CATS.
So there are 2 different LT1 kits..
I didn't think there were all these trouble using CATS...
MINE IS 1995
Any other software that is trouble free?
I modified my main PCM. Soldered in a ZIF socket for both flash chips.
I can pop out the flash with ease.. I have 2 emergency spare flash, I purchased from one of the last sources. I also have a stationary setup with a power supply to program the PCM in my house. And yes. I'm always nervous. I was silly. Just last week. Data logging. And perfecting my tune. Flashed from my laptop. The battery went from 50% to Zero and turned OFF. The 1st stage erases the flash. I was stranded. I have 3 PCM's Currently modifying a 2nd one.
Assuming for a moment that someone don't replace flash and get a CATS session on vette.
At one moment programming is interrupted, at this point 1st stage erases flash
What excatly happen. Car will not run anymore?
If there is a will there is a way. I bet someone could make another ECM out of conventional eproms and it would work with our cars. Has to be possible. Just ones and zeros.
so this "chip" can not be found anymore? Has anyone looked at the part number and looked for it thru some place like Digikey or some other place like them? I believe you as I have read this before but still wonder if this is totally true. Heck, I just bought a spare ECM of ebay for my car last month for tuning purposes. Is the ECM hard to get or is it just the chip?
You can find 29c512 Flash.
to convert as you mentioned. you would need a 32 PLCC socket adapter to a 32 DIP socket. There are such adapters.
Saving your bin. Is pointless. I have multi copies of My Bin. Again 1st stage in the flash process it erases all data. If you loose connection. There is absolutely NO way to communicate with that PCM in this Stage. You must not flash as much as i do. loosing connection does happen or battery drain on the road using a PC. The cars dash itself sends out signals that could inter-fear.
Of Course we all looked at the PN: AN29c512 the PCM takes 2 of these 32 PLCC flash proms.
Excuseme the question but this topic is a little bit complex for me
Datamaster as far as I understand, shouldn't makes problems, Don't you?
Its purpose is to monitors and records datas and as long as i'm not going to re-programming there's no that 1stage problem, am i right?
Is CATS tuning program the application that makes that trouble?
If IAC counter is not properly stored, to re-learn it, Can i run through the 1stage erase trouble?AS far as I understand i would say yes, but i'm not sure what is tuning what's not
Thx 383
That being said one time while driving around datalogging with DATAMASTER, something happened to my laptop. It caused the car to die and I could not restart it. Finally I disconnected the battery let it sit a while and it restarted*. Since the vette is my daily driver I immediately purchased a spare PCM. (Now have a second PCM with my current tune installed on it and I ensure that my laptop wont go into sleep mode and has plenty of battery life while data logging)
Mike
*was not a five minute problem
I just want to state for the record. I have never had an issue with CATS or when tuning the car IE flashing a new tune.
Mike
Mike
Fortunately was not a huge trouble seems, but a trap is always behind the corner using these applications.
However to get a spare pcm is a nice idea,
Mike
Mike
