93 LT1 runs rough when engine is warm
Car has new:
Opti(last summer)
Taylor wires(month ago)
AC Delco plugs(last fall)
FIC Injectors, 24lb(2 weeks ago)
AC Delco FPR(January of 2015)
Coolant sensor(Summer of 2015)
Both O2 sensors(work fine based on the scan, replaced in May of this year)
I might be forgetting something, I will post if there is something missing.
EDIT, new Fuel Filter(about 2 months ago)
Oh, I'm lean on the left bank. BLM is 140-150. Almost spot on the right bank with BLM at 124.
So what can be causing my car to run rough when the engine is warm?
Here is a plug from cylinder number 3, just for the hell of it.
I've done everything I can, so I took it to a shop my family has been using for 20 years. Mechanic found an exhaust leak at the driver side exhaust manifold. He says the opti is the cause of the rough idle. I doubt it's the opti. Sorry for the long post. Car is a 93 LT1 auto with just under 79k miles. Hopefully I am making sense
When I turn the AC on, the idle is noticeably smoother.
Antfarmer, I don't have overheating problems. Car doesn't leak or burn coolant.
The LT1 is prone to an intake gasket failure.
Check the back of the engine block for oil leaks.
A small leak here and a small leak there all become accumulative.
Regards,
Roy
U have some fancy spark plugs there. Did u have those before the rough running started. Try a return to stock plugs again. Measure the resistance of all your plug wires and look for arcing in the dark w/eng running.
Try a real time scan. I found a AutoXray scanner for my '94 OBD 1.5 at a swapmeet brand new in the box for $40. I can real time monitor most paramenters (cant print or store them though). I believe there is some "trial" software u can use if u have a cable for your OBD I connector and and laptop w/RS232 serial port.
Let us know how the exh leak changes things.
Regards,
Roy
Opti right? If so, I guess Petris is the way to go?
Do I use thermal, or di-electric grease?
What brand ICM do you guys recommend?
Just pulled this from the FSM. Hopefully to help someone in the future,lol
