my c4 is making noise
I have a 1991 corvette and it's making a pinging noise like something came loose inside of it. And now when I put it in gear I have to rev the engine up to get it to move. Anyone have any idea what that could be. I recently put in a rebuilt trans with torque convertor in it.
Black LS2 (10-10-2015)
It's a steel clutch, sprag type. It sounds like it is dying and what is really bad about that is it generates debris and screws everything up in your controls.
You may be looking at another rebuild. Failed converters are bad business. I use CVC converters because the quality is high.
Many aftermarket converters are junk. They go down and take a million things with them.
IMVHO.
Drop the trans pan and look for bits and pieces. If nothing obvious is found...
Open the filter and check for "interesting" stuff inside. This is what was in my filter after my new torque converter self destructed after 150 miles:
