86 Drastic Steering Pull When Brakes Applied
Old Oct 13, 2015 | 10:06 PM
21boy's Avatar
21boy
Default 86 Drastic Steering Pull When Brakes Applied
Hello,
When you touch the brakes, its been pulling to the left hard enough that you have to fight with it to stay straight since I bought it. Mechanic swore it was calipers and lines, so replaced both. I re-bled all lines (furthest to closest) after a few weeks of it continuing. I changed the brake pads too on both front wheels. Master cylinder is topped off as well.
Im out of ideas and dont want to keep throwing parts at it that arent the problem.
Very interested for some insight, Thanks!
Old Oct 13, 2015 | 10:17 PM
antfarmer2's Avatar
antfarmer2
maybe your rubber lines are swelled up restricting fluid?
oops sorry did not see you did that hmm
did you trace the lines back and look for kinks or dents?
Old Oct 13, 2015 | 11:36 PM
xrav22's Avatar
xrav22
Dis you grease the pins they will dry and stick
Old Oct 14, 2015 | 07:40 AM
21boy's Avatar
21boy
Not sure I follow what pins?
And I havent followed the line, would it go back to brake booster?
Old Oct 14, 2015 | 07:54 AM
antfarmer2's Avatar
antfarmer2
the pins that the caliper slides on.
and the steel lines that go to the master cylinder.
you did put new rubber lines to the calipers right?
Old Oct 14, 2015 | 09:06 AM
c4cruiser's Avatar
c4cruiser
The caliper guide pins have to be greased in order for the calipers to slide. New calipers should have come with a small packet of grease. The pins are held in place by the rubber seals and attach to the caliper bracket with the two small bolts you loosened to remove the caliper from the bracket.
I would suggest getting a new set of guide pins, seals and bolts. These are pretty common on most GM cars from the 80's on up thru the C5 brakes. They aren't expensive and some parts stores will even carry kits made by the aftermarket if not AC Delco parts.
Old Oct 14, 2015 | 11:49 AM
21boy's Avatar
21boy
Correct
Old Oct 14, 2015 | 12:33 PM
yorkfitter's Avatar
yorkfitter
Had the same thing happen to me and it ended up being the abs pump. After driving feel the front wheels and see if one is getting hotter than the other. If it is take that wheel off and release the pressure with the bleed screw and that wheel should spin freely again. If that wheel continues to get hot after this, your abs pump is keeping pressure on that line even when no brake is applied.
Old Oct 14, 2015 | 03:01 PM
21boy's Avatar
21boy
So did you just replace the abs pump? Or rebuild/clean?
Old Oct 14, 2015 | 03:04 PM
yorkfitter's Avatar
yorkfitter
Eliminated it.
Old Oct 14, 2015 | 03:33 PM
21boy's Avatar
21boy
Originally Posted by yorkfitter
Eliminated it.
So what, does your abs light stay lit, and no abs?
Old Oct 14, 2015 | 04:46 PM
yorkfitter's Avatar
yorkfitter
I removed the pump and the module and I have no light on. When this happened it was 400 to 600$ for a new or rebuilt one. You can look for a used one on the forum for cheaper, but I have not seen them come up very often.
Old Oct 14, 2015 | 05:01 PM
21boy's Avatar
21boy
Hmm would a good way to this be to unplug the relay/solenoid?
Old Oct 14, 2015 | 05:53 PM
21boy's Avatar
21boy
Just did some quick research into the abs system... ive never heard mine actually work. Thinking i may actually have a bad component in the system, possibly causing unwanted braking.
Ill take a test light to the relays and ill grease the pins on the calipers and try not to turn left when I want to stop
Thanks for the help!
Old Oct 14, 2015 | 05:59 PM
yorkfitter's Avatar
yorkfitter
If you want my module let me know, just pay for the shipping.
Old Oct 14, 2015 | 09:14 PM
barbedwiredave's Avatar
barbedwiredave
If everything else checks out I agree with the ABS pump. Mine was holding pressure on the front driver side. Bought a used one off ebay and that fixed the problem. Yorkfitter do you have any pics of your pump elimination? If it happens again I'm gonna eliminate it.
Old Oct 14, 2015 | 09:29 PM
yorkfitter's Avatar
yorkfitter
It has been awhile since I removed the ABS. Since it is a Bosch the lines going in were metric. I ended up cutting the lines for the front and re flaring them for a standard SAE flare and buying a tee to from my local car parts suppliers. I also changed the rear to SAE with a coupling. It is not pretty and hard to do in that small of a space. I have been meaning to redo it under the car but have not found time or motivation.
To 86 Drastic Steering Pull When Brakes Applied
Old Oct 15, 2015 | 07:20 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Hello,
I had a car that did that. Wound up being a bad belt in one of the tires. Rotate front to back cleared up my problem for the most part
Old Oct 15, 2015 | 07:35 AM
hcbph's Avatar
hcbph
check with Pat (See4Parts) as he disassembles quite a few C4's apparently. He's had the ABS pumps before at reasonable prices.
I looked at one time for places that repaired or rebuilt those ABS units in the past and did not find anyone fixing them at this time.
Old Oct 16, 2015 | 12:13 AM
21boy's Avatar
21boy
Even with new tires? Mine have
Last edited by 21boy; Oct 16, 2015 at 08:40 AM. Reason: Less than, not greater than.
