have a question about fuel tank baffle asap
Ok I have my fuel pump out and found the baffle just sitting on the bottom of the tank. Where should it be?
your fuel pump sock will sit in it
Fuel pickup baffle
Why do you have your fuel pump out?
I had a problem that my 93 vert would stumble when cornering on a 1/4 tank of gas. Others said that the baffle (little tray) had probably come unattached from the bottom of the tank, and that its purpose was to keep the pickup submerged in gas to prevent starvation when cornering.
Their solution was to cut a Lucas gear oil bottle in half and puncture the bottom and fasten it to the fuel pickup.
(Are you having these fuel starvation issues??)
So I took out the fuel pump to see what was at the bottom of my tank, and lo and behold, the little tray was still properly attached.
So, if you have starvation issues, putting in the modified Lucas Gear oil bottle may solve it. do a search on this forum for the whole thread.
Hope this helps. (I still have the cornering-starvation issue!)
Baffle
Here's a post on this topic:
https://www.corvetteforum.com/forums...-throttle.html
go to post 11.
Good Luck
go to post 11.
Good Luck
I took it out to change the old sock and glad I did, it was brittle and half the size of the correct part. Now the fuel starvation, I would get this autoxing if I had less than 1/3 of a tank so I would make sure my tank was full before hand. The baffle broke loose so for the time being I took it out.
Here's a thread with a snapshot by Cliff. I mentioned how the early GM trucks were secured in the same thread. Can you feel the rivets that secured it originally like I mentioned in that thread? If you can feel the studs then perhaps the 1/8" push-nut would repair.
https://www.corvetteforum.com/forums...e-problem.html
the plastic tray in the bottom of the tank is next to useless, but would help some if you were really low on fuel and trying to get to a gas station.
I have spent some time trying to overcome fuel starvation in my car, one thing I found is that the pump and sock actually sit at a 45 degree angle in the tank. when you have your assembly out have a close look at how it sits in the tank. This angle actually points the sock out of the tray.
Any way I have used a piece of 3" PVC pipe around the pump and it works perfectly.
The PVC has been in the tank most of this year and there has been no deterioration of the plastic, I checked it before my last hillclimb meet a week ago.
Probably a much easier fix than trying to re-secure that tray.
Adhesives don't work submerged in fuel, I ended up using cable ties and a few small holes in the baffle. Cable tied the baffle to the fuel pump sender assembly and it works great, bit tricky to get in and out the tank but I am happy.
There are two ridges in the tank, that the baffle sits between.
As others have mentioned an old oil bottle should do, I do like blackozvette's solution.
You know the old saying, necessity is the mother of all inventions
Max G’s
What did you end up doing? I use fuel tank foam but still have to have at least 5gal in the tank. I was thinking I would like to get one of those Holley Hydra Mats but I can't get the sump(baffle) loose. I tried to pull on it before and thought I was at risk of pulling through and having holes in the bottom of the tank.
I bet you could get that hydra mat and fuel tank foam and run as little as 2gal in the tank
I have not used it but have heard good things. I would check your fuel filter and leaky pulsater first or someone replaced it with the wrong type of hose.
cvg323 asked for an update, here's a couple more pics,
after checking the pvc after a year in the tank , the only adverse effect it had was to shrink slightly. it went from being 3" to being slightly under (it would fit into an original piece of the pipe) see pic below.
I wasnt sure if the PVC would continue to shrink so I made an alloy shroud.
in the pic below you can see it compared to the pvc one - this is the mark 1 version, I bent out the ends to protect the fuel sock more, but had issues getting it into and out of the tank hole, so had to make another one, more of the original 3" round and less of the bent out.
The shroud works well, the alloy one has been in there the last 3 years without issue. The hydromats are quite expensive and would require removing the plastic tray to work in a c4 tank.
It provides a barrier to the base of the pump where the sock connects to stop the fuel being pulled away during hard cornering. the 3" size is the maximum you can use and still squeeze into the plastic tray.
I did try fuel foam, but that swinging fuel gauge arm and float doesnt like it !
