rusted fuel sender issue?
Old Nov 16, 2015 | 05:36 PM
czarredd's Avatar
czarredd
Default rusted fuel sender issue?
My fuel pump wasn't getting power when connected to the harness on the fuel sending unit therefore it was straight wired from the gas tank to the engine to power on with car ignition. I'm about to purchase a new fuel sending unit (going to replace pump too) and was wondering if because my current unit is so rusted the wire to power the pump was bad.....and when new fuel sender is installed and harness connected-----no more straight wiring??? Has anyone experienced that before? Thanks
Old Nov 16, 2015 | 05:41 PM
antfarmer2's Avatar
antfarmer2
I would give the tank a good cleaning and flush the lines and a new filter.
Old Nov 16, 2015 | 05:58 PM
czarredd's Avatar
czarredd
Is there a way to drop the tank without having to remove rear bumper?
Old Nov 16, 2015 | 06:03 PM
antfarmer2's Avatar
antfarmer2
no just mop it out the top good. a long lanky kid with a stick would be great.
Old Nov 17, 2015 | 12:23 AM
Cliff Harris's Avatar
Cliff Harris
The fuel pump has power applied under two conditions:
1 - 2 seconds when the ignition is first turned on.
2 - When the engine is rotating.
If the car is just sitting there and not running there will be no power at the fuel pump.
Old Nov 17, 2015 | 10:37 PM
czarredd's Avatar
czarredd
Thanks as always for the info Cliff but I totally understand how power is applied to the fuel pump. My issue is knowing if its possible that the power wire to the fuel pump could be bad.....which is why my pump had to be straight wired for power. I'm wondering if anyone else has had this issue and had to power fuel pump this way.
Old Nov 18, 2015 | 12:01 AM
Cliff Harris
I would connect a 12 volt test light to the fuel pump power wire and turn on the ignition. The test light should light for 2 seconds if all is well. Disconnect the direct connection to the engine first...
Even if the fuel pump relay is bad the oil pressure switch should take over when oil pressure reaches 4 PSI.
Old Nov 18, 2015 | 12:14 PM
whalepirot's Avatar
whalepirot
You are aware (or not) that the pump/sender assembly is easily removed thru the filler lid opening with no tank removal needed. There's a tin of threads on this topic.
If there's big rust issues, I'd surely inspect inside the tank, however. the 'sock' filter's condition should give you some indication of severity.
If you retain the "direct" wiring, I'd suggest a rollover protection device to cutoff power in that event. While I'm a fan of factory design's comprehensiveness, shutoffs are not expensive and may be a lifesaver.
Old Nov 19, 2015 | 10:18 PM
czarredd's Avatar
czarredd
Thanks. Yes, the sender is pretty easy to get to....it's just this wiring that has me puzzled. I guess we'll see when I install another sender. Thanks again!
To rusted fuel sender issue?
