Egr question, still comfused
Old Feb 13, 2016 | 12:10 PM
mlm0's Avatar
mlm0
Default Egr question, still comfused
I want to get rid of my egr. I don't have to worry about passing smog
test anymore, but I still have questions, even after reading all the info I could find on this site
89 stock L98, auto transmission
I know I have to use block off plate on manifold where egr valve is now located. I have to remove vacuum electronic control mod and plug vacuum line. Do I need to do anything with pipe that comes from exhaust and the temp switch that is on the pipe? What do I have to do in the tune to not get code for egr problem. I think I have decided that my random miss at idle is from the egr valve not completely sealing off the flow at idle due to carbon build up inside of manifold. I think it would just be better if I just get rid of it completely. Are there any down sides to this?
thanks in advance
Mike
Old Feb 21, 2016 | 02:30 PM
AQUILA163's Avatar
AQUILA163
The down side is light throttle detonation. Just fix it, there is no performance handicap in keeping EGR and it allows you to keep more timing in the engine.
Old Feb 21, 2016 | 03:30 PM
aklim's Avatar
aklim
thanks in advance
Mike
If you are talking about writing the code in the program for the ECM, maybe the "Tuning" section will work? For your car, I believe you are going to have to remove the EPROM, flash it and re-burn it and reinstall. At least that is what I saw done when they did my dyno tune.
Old Feb 21, 2016 | 03:32 PM
aklim's Avatar
aklim
It can break and it clutters up the engine bay. My engine is cleaner with the EGR, Vapor canister (F-body. Y-body is in the back, IIRC) AIR system removed. Besides the HSR doesn't allow it. Still, it makes things easier to get to.
Old Feb 22, 2016 | 05:37 PM
gerardvg's Avatar
gerardvg
thanks in advance
Mike
Hi
You can download tunerpro (www.tunerpro.net), you have to buy an ostrich emulator and download the bin and data stream definitions for your year corvette. Then you can do tuning and remove the EGR check tick yourself.
Or pay someone to do it...
Maybe visit the C4 scan and tune section first, it can be a steep learning curve for some.
Old Feb 23, 2016 | 03:18 AM
aklim's Avatar
aklim
Originally Posted by gerardvg
Hi
I would think it is easier to pay someone to just remove the EGR check tick. By the time you have bought all the stuff to do it and spent all the time deciphering what to do, I could get someone to do it sight unseen for $275 http://www.hitechmotorsport.com/tuni.../gm-base-tunes and have no headaches and no pieces of equipment sitting around and eating up real estate. OTOH, if you are making either enough changes to justify reprogramming every week, that is different.
To Egr question, still comfused
