Anyone break the crankshaft nose with supercharger?
I was talking with the CEO of Scat yesterday and he said that the small diameter of the stock sbc crank nose makes them susceptible to breakage when turning a blower drive or dry sump pump. The added torque generated with a 7" pulley will eventually twist the nose off the crank. Has anyone here experienced a problem with that happening?
Scat makes a crank with a bbc diameter nose on it to relieve the stress on the crank nose.
Jim
Jim
No. Still stock diameter but much harder material.
There are BBC snout sbc cranks out there as well as the timing set to go with it.
FWIW the vortec series blowers are not as hard on the snout as procharger or PD blowers due to the higher (lower numerically) gear ratio within.
LS3 uses a a cast crank. I know people spinning them to 7-7500 and making 800-1000rwhp on a blower setup. That is a completely stock crank.
If that can survive so can any belt driven setup on a forged setup.
Cog or gear driven blowers are a different animal altogether.
Anything can break but with proper tuning and not sitting on the limiter it should not be an issue.
i could see an issue with a cheapo 'eAgle' cast crank, for example.
prob the oe cast crank is made with better materials/ metallurgical techniques.
though everything has its limits at some point
