1991 c-4 motor replacment needed coments?? sugestions?
Okay here we go; i just purchased a 1991 c-4 black roadster 6 speed car that had been sitting for approx. 10 years, owner windowed the block so it was not in the pakage,but most of the parts are, so we are in need of a sbc replacment; stock 350 or 355 or 383 or 400 or 408 or 417-427cu, what say you.....thanks
sorry, forgot to add that i did get the aluminum heads and intake with the package, sans; clutch disc,pressure plate, t-bearing, slave cylinder flywheel,distributor, may show up later as inventory gets a better look, or a member may have them for sale,..thanks
You didn't indicate your use goals, but assuming stock replacement type and budget would support:
http://www.summitracing.com/parts/na...1723/overview/
Actually a slight upgrade from the stock shortblock. You'd have to add cam, lifters, and all the retaining stuff; pushrods, oil pan, front cover. And whatever else you can't locate that you'd need to get it running.
More complete:
http://www.summitracing.com/parts/na...0282/overview/
Would require a different TPI base. A better cam would be nice, and probably better valve springs.
Another option, more money:
http://www.summitracing.com/parts/na...2532/overview/
More complete, better heads, more power. Has stuff you won't use/need to switch. If you stay with TPI, you'd need a Vortec base, probably bigger injectors, ECM tuning.
There are literally hundreds of options. You need to decide on your goals, budget, etc.
More complete:
motor
More complete:
More complete:
