Dtc 65
Dtc 65
Has anyone dealt with a DTC 65? ASR Circuit ground to short?
With the cables to the ASR motor disconnected and rotated the DIC light doesen't come on, yet when I rotate the TP sensor the ASR light comes on?
It's been mentioned I believe multiple times a B+ fault to the EBCM for a DTC 65
I replied to your PM and here as well. I think we talking about the ASR LOL.
You need to check the harness both wires for a short to ground, short to power, or shorted to each other from what I am reading. They could also be open, test from the one connector or at the EBTCM.
A FSM would most helpful in this case. There is a two page flow chart+diagrams.
You don't need it to test the above items its only two wires. I assume you understand how to use a DVOM to test for those? If not, you going to need to do some research on Youtube,etc....hard to explain on a forum and via words you really need to see it/do it.
