Power antenna issue
I am having an intermittent issue with the radio. They symptom is poor reception. Some times when I am stationary it is perfect. The stereo indicator flashes pretty bad on the head unit. In my experience with radios this is usually an antenna issue, which makes sense because occasionally when I drive it drops out.
I suspect the small ground wire at the base of the antenna, or the connection from the antenna back to the cable that connects to the head unit. Both which are in the same area. Before I go pulling the rear wheel and the molding, is this a common issue with the antenna.
yes I know its a Bose, yes I know they pop and hiss, but this one has only a little whine. Has not been driven much, but it just sounds like a bad antenna ground or connection .
What says the brain trust ?
I brought a brand new 1989 RX-7 That I still own, when I first got it brand new I remember pulling in stations a good 75+ miles way, today the same stereo can barely pull in a station 15 miles away.
If its just a reception problem, I suggest a smart phone, iheartradio, and a cassette adapter and/or bluetooth transmitter.
If you're going to go after the antenna you need to confirm the ground strap and clean/confirm the RF connection on the mast & tube. The RF connection to the mast is I believe secured with 2 sheet-metal type screws (not sure but earlier were). Perhaps someone has one out of the car and can lift the weather-boot to confirm.
#0000 steel-wool to clean mast.
If it functions (up/down) I believe it a worth while effort.
I understand what you are saying about components aging. However the symptoms are too much like an antenna issue for me. I know the antenna cable from the head unit connects to the power antenna unit somewhere around or near the speaker behind the driver side under the carpet. I will check and confirm there first.
Just the way I can be driving and have great (for Delco BOSE) reception, then have a little bump and it goes out, screams connectivity or grounding to me.
WVZR-1 I agree that its probably worth an hour or so of my time to pull the rear wheel and molding to look and make sure the ground etc are good.
Thanks again for the help guys !
Ground strap on the power antenna is good on both ends but it is a little corroded.. kinda blue ish copper fur on about half of one side.
Ran a separate ground and nothing changed, so I went digging.
I wanted to find the male / female connection in the area of the driver side rear speaker for the power antenna ( the mast connection) and found a coiled up approximately 3 foot long second, hideaway type antenna. IT is attached to a approx. 2 inch silver color box that is mounted under the hatch release. It was getting late and I did not want to dig further so here is the plan.
Locate the male, mast connection from the factory power antenna. Locate the female part of the antenna cable that goes from the head unit to that crappy silver antenna box.
I'm going to restore the factory antenna connection and then troubleshoot from there.
Has anyone ever seen or used one of those hideaway antennas before ?
