94 Random Stalling
94 Random Stalling
Been having a problem with the wifes 94, Random Stalling. Seems to be quite common with this year.
A little history,
Petris Optispark- 17000 miles ago
water pump- same time
new Fuel pump, sock, filter 2 day old
ICM less than a week old
No consistant stalling, could be at intersection, when first leaving a stop sign, driving yesterday it shut off at 70 mph on the highway
Usually restarts after 2-5 mins
I pulled codes ... nothing. Until it actually shut down on highway
1. H16- Distributor ignition system, low pulse
4. H62- Engine oil temperature circuit low voltage.
So based on those 2 codes what direction should I go in?
A little history,
A little history,
A little history,
Did you use the proper thermal grease on the ICM? And test the coil?
Pulled the coil, cleaned ground up.
Checked ohms on Lo/Hi side. Doesn't make much sense that both sides read shorted on every scale.
The car will start up or could it still get spark if shorted?
If your saying you have continuity between the primary and secondary sides of the coil then that doesn't make sense to me either.
I think if I were you I would do my best to get the car into the failed state and during the 2-5 minutes it seems to take before it will restart, I would do my diagnostics. otherwise your limited to throwing parts at it.
Just to be clear I tested the LO side first then tested the HI side. Let me correct the term "shorted", not the best word I have chosen. I'll say "open" since in theory neither the LO or Hi sides are allowing voltage thru. Since the meter is reading 1. on all scales
I wish I could. I drive it and it hasn't stalled on me yet. Its to random. It could run for days fine... then bam.. it stalls. Idle/ while driving doesn't matter. All I got so far is those codes nothing else. I'm gonna pick up another coil and test the resistance to see if it reads the same. I don't see how a coil that reads as shorted on both sides can allow spark.
Its been a very, very long time since I put an ohm meter to either the pri or sec side of any coil, but there should be almost no resistance. Now I don't know what multi-meter your using but every meter I've seen reads "OL" when you have an open circuit. So when you say "1" it makes me think you just have something besides an open circuit.
Bottom line. I don't think the coil is the problem, but you need to test it while its in the failed state before you can tell for sure. I suspect you knew that already....
not sure what the specs are of the one I just took out of the car its either a AC Delco or Taylor. Can't remember which I put in it a few years back.
If its a Taylor
Primary Resistance:
0.440 ohms
Secondary Resistance:
3.1K ohms
So if I use a ohm meter those are the readings I should have, or at least close.
When using the ohm meter on this one I get readings of no resistance on primary ( which on my meter is 1.) and the same on the secondary.
no resistance would mean in a general term that there is no "path for voltage to pass thru".
If I had gotten a 0 then the path would be considered a short in this case.
And to even put it in a simplier example a closed contact would read 0 on a ohm meter and a open contact would read either a OL or 1. on a ohm meter
So if I have no resistance on both the primary and secondary then how is this car starting up? That at this point is my question
If its a Taylor
Primary Resistance:
0.440 ohms
3.1K ohms
So no voltage/amperage will NOT flow thru the wire..
