Missfire and knock retard
I went WOT yesterday, and felt a Missfire at 3,000 rpm. Earlier this morning, I was curious to see if I would get any knock on my scan tool. Sure enough I did. I was driving and wasn't able to read it good, but I did see it go away from zero. I believe it was at about 4, the knock retard. The miss seems to be more noticeable today. Yesterday, I only felt it once at WOT. Today, I felt at part throttle. Though not all time. Hope I am making sense. Just checked for codes, none. Put 93 octane in it last Tuesday.
How old are your o2s? How many miles on it?
I would take a look at them for melted wires. What brand did you use? Also look for anything loose like motor mounts or exhaust banging that could set off the knocks. And the wires to the knocks might be shorting out.
Fuel looks good.
Just let the car warm up, checked for arcing on the plug wires, none. Question, would something with the knock sensors cause the hesitation/misfire? As I said, it doesn't always misfire. I was looking to do the test that 93rubie shows on how to test the opti with a multi meter. But I don't know how to make t pins. No loose exhaust or anything.
Before going out for a ride today, I tested fuel pressure just because. At first key on, engine off, it only went to 24 psi. Went to key on again, then it was at 42 psi. Could the fuel pump be going bad? It ran great, no misfire. Knock on wood that it stays that way
Not unusual. I wouldn't worry about it.
