Did Seafoam Kill my Vette? I'm stressed!
#41
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
#42
People got to try all the placebos, snake oils, whiffle dust, mouse milk, etc. There is no real "mechanic in a can" that will go in and magically fix everything for you. If you want to clean something, take it apart and clean it so you KNOW it is clean.
#43
Someone please give me the stupid/lucky idiot award. I opened up the fuel tank, stuck a flashlight down in it, BAM!!!! Bone dry! I'm feeling really dumb right now. Going to clean the tank and put everything back together. I should have known better. It was too good to be true to buy this car with a full tank.
#44
LMAO...I can't believe it myself.......I'm still moving forward with the fuel filter change. I just put two gallons of fuel in her and she fired right up without any fuss.
#45
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Its empty! Nows the time to pull the pump and wipe the tank dry.
Swap in a fresh filter and all the other fuel stuff everyones been pointing you towards.
You might as well start off with a clean system rather than go thru this s**t all over again....
#46
Pro Mechanic
#47
So one issue resolved and a new one pops up. So my tank level bars on the digital read out say my tank is almost full. But the Range says I have 65 miles of fuel in the tank. Something screwy with the sending unit?
#48
Pro Mechanic
Your current average mpg is probably pretty horrible right now (based on the car's recent driving), so 65 mi range on a nearly full tank is possible.
What is more important is this; the gauge reads "almost full"....is the tank really almost full?
#49
Maybe...maybe not. The range is a function of gallons in the tank as monitored by the float/sending unit...and your average mpg. Your current average mpg is probably pretty horrible right now (based on the car's recent driving), so 65 mi range on a nearly full tank is possible.
#50
Pro Mechanic
#51
I looked at your gauge in the vid. It's whack if empty. May I please be so bold as to suggest that you change the oil before another jubilant start? We are cringing at the thought of whipping a sick pony.
It's your car, but there is some prudent advice in this discussion. I love hearing your story but after that fan switch.... you have some pre-flight checks that need attention.
#53
#54
If I'm not mistaken, somewhere on this site is a walk through on how to clean or repair a C4 sending unit ..You may want to give that a try before buying a new one......WW
Here is a video on the subject..
Nomad74 (07-28-2016)
#55
https://youtu.be/Au1C9Q009dY
#56
I got your PM this morning. I was on a job site but i'll shoot you a call later. Thanks for all the advice! All you guys are great.
#57
Pro Mechanic
#58
I can't believe that you just said that! There most definite IS such a thing! Says so, right on the can!!
Attachment 48004140
Attachment 48004140
#59
Let's go with that. Say it reads full when it is empty. How does the range meter get it's numbers?
#60
Received 3,043 Likes
St. Jude Donor '05
holy ....you got 9 lives man. Shop vac, gas and youre still alive?
Go buy a lotto ticket
sorry but
made the mistake of forgetting to put the filter back on vacuuming up a pile of aluminum shavings once what a spark show but gas...
