Screeching AC Compressor or Clutch Pulley?
I've got an intermittent high-pitched screech coming from the AC compressor and I can't tell what's causing it. I don't hear the noise if I pull the belt and spin the pulley. If I take some tension off the belt tensioner while it's running, the noise seems lessen. Anyone come across this or have a better way to isolate the problem from the clutch, pulley or compressor? It's an '86 and the tensioner is new.
One Question I did not Clarify, Does it do with the A/C off? because that can rule out a lot of the Super Expensive A/C parts.
