brake master cylinder
just curious - besides being a new and not rebuilt - does any one have any experience with cardone, centric or raybestos brake master cylinder? or even another brand that you trust?
bleeding the system does not seem to have helped the brake pedal hold.
any help would be greatly appreciated
thanks
Sean
thanks
Sean
thanks
Sean
thanks
Sean
sb66 (07-30-2016)
thanks - did you buy one of those brake bleeding kits?
Bought a brake best reman unit from oreillys earlier this year. Came with the bench bleeding kit. Looks like oem casting. So far so good. Better than the worn out unit it replaced. I bought a set of speed bleeders to bleed my brakes with. Makes the job soooooo much easier.
sb66 (07-30-2016)
thanks - forgot about the speed bleeders - I have been doing it the old fashioned way someone inside pumping away while I open and close the line
I had heard that tool was pretty cool - but a little bit of $ too?
anyone hear anything about "dorman" products?
