94 Door linterior door lamp
94 Door Interior door lamp
I replaced the door lamps in my car with LEDs but what is the tiny # 73 lamp, I do not see it light up. There is one in both doors inside the lens housing near the courtesy #212 bulb and I found one in the rear view mirror map right side lens.
Not sure about earlier years, but the '96 and I believe '94-'96 used what might be called "mood lighting" when the headlights were on.
Very soft/low light on each door and the bottom of the mirror housing.
These are not the same map lights that Mark mentions though.
thunder1951 (08-02-2016)
I believe those are actually called "DOOR HANDLE FLOOD"
