connecting wires together
Hi joe the update is that I got the part in the mail but it turned out to be the wrong one .It could be tweaked to make it fit , but i'll wait for a fresh one to be sent out .Also ended up buying some heat shrink connectors which I will try to set with a hair dryer . If that fails western union here I come ,,,,,hehe . Take care champ , cheers
close but no cigar .
This is how a 150.2 is assembled:
http://www.theelectricaldepot.com/pd.../Pull2Seat.pdf
The 150.2 "pull to seat" would need to be removed through the face (front) of the shell rather than "out the back(rear)" as most are. A T-needle usually suffices for a release tool. A correct release tool is this. You can "zoom" this image to see the action end of the device.
https://www.waytekwire.com/item/431/...Removal-Tool-/
The tool would be used through the rear of the shell vs the typical through the front for release.
