C4 transmission
Old Sep 4, 2016 | 10:09 PM
Cndcarey's Avatar
Cndcarey
6th Gear
Default C4 transmission
Need some advice... 1988 c4 trams is making noise and leaking. Should I rebuild it or buy new/better trans instead.
Old Sep 4, 2016 | 11:29 PM
DMITTZ's Avatar
DMITTZ
is it an auto or manual?
Old Sep 5, 2016 | 07:45 AM
Cndcarey's Avatar
Cndcarey
6th Gear
Automatic. Making a screeching sound when shifting into second.
Old Sep 5, 2016 | 07:47 AM
arbee's Avatar
arbee
2nd gear involves the band. What does it do when it shifts to 3rd?? 4th??
Old Sep 6, 2016 | 06:53 AM
Cndcarey's Avatar
Cndcarey
6th Gear
Shifts hard into second, don't recall noise in other gears
Old Sep 6, 2016 | 07:34 AM
cadmaniac's Avatar
cadmaniac
I'd put a bottle of Lucas transmission lube in before I'd start pulling it out. It's cheap, and can't hurt anything if it isn't able to stop the noise.
Might buy you some time, anyway.
Old Sep 6, 2016 | 08:08 AM
arbee's Avatar
arbee
As cadmaniac says, it may buy you more time, but I don't think magic in a bottle is going to cure your problem. You describe leaking, "screeching" sound and hard shifting. The hard shift could be caused by many things - high line pressure, broken 1-2 accumulator etc. Screeching noise COULD be a band that has lost part/all of its lining. COULD be a rear roller clutch, as this begins to turn in 2nd. gear. Make sure TV cable is adjusted properly. Probably need to drop the pan and look for anything that shouldn't be there. Having the pressures checked as per the chart is probably in order.
To C4 transmission
