looking for belt routing diagrahm minus air pump
Looking to take off the air pump so what belt size would I need to do this and any diagram on how the belt should be routed, I am Maryland, so there is no emissions to worry about when the car is 20 years or older
On my 89 I had to add a pulley and bracket , I couldn't just change the belt length.Im not positive about the 84 Corvette..WW
Yes on an 84 you can just pull the air pump. The belt routes the exact same way as before. just used a shorter belt. I believe you need an 85" belt if memory serves me correctly. Also I am sure it has been covered many times so searching would also be a benefit
