Rear spring to Differential Cover - Question
I apologize in advance for sounding like an idiot. I don't know the actual name of the part in question, and I'm not too knowledgable with Corvettes.
Anyway, I bought a D44 and batwing, separately. On the cover, where the mounting brackets and bolts for the spring are, there are what looks like shims of compressed cardboard. They look pretty gnarly, so is there a solution to replace them? Should I scrape them off and just use the 1/8" metal spacers above and below the spring?
Thanks!
Thanks!
What you use would maybe depend upon many things. Is it to be used in a C4 corvette or is this a D44 that's been purchased for use in something "other than" it's C4 intentioned install?
The shim/spacer isn't part of the D44 set-up, it's actually a part of the suspension component. It's very dependent on the spring rating and variables such as a 'vert or a coupe etc.
The rest of the suspension is from a 90 coupe with a D36. It had 6 1/8" shims, 3 on each bracket.
Still, those cardboard-y shims glued to the batwing, what to do with those?
It will not be used in a Corvette. I'll swap it into my S10 (lots of work and ultimately stupid).
The part is meant to be an "insulator" and when you tear the D36 out you'll find I'd think the same unless someone has been there and modified things.
If you're using the transverse spring your only concern is the total shim stack height so that it fills the spaces above/below spring and allows the clamping action that secures it. the insulator itself isn't hurting a thing and appears to be in reasonably good condition. When you put the D44 in the current suspension just duplicate the shim/spacer (count and thickness) that you're using with the D36.
Just in case, does GM still make those insulators, or is it easy enough to make my own?
Thank you for the knowledge! I wasn't sure if the insulators were still good to use, since it looks like the stack on the left doesn't have a flat surface for the shims, whereas the right stack does.
I didn't notice the deterioration of the one insulator, I only glanced at the snapshot and read your post.
