86 hard to start when cold.
Just recently my 86 has decided that it was going to be a pain starting when cold. Used to be it would jump to life, then it got where I would turn key on, crank it over turn off then crank it would run good, idle like it supposed to. Now, no matter what it kind of just blubbers to life and after it warms up it is ok. Is this my CSI? If so, where can i get one. If not, wht should I look at? Have changed the IAC and the TPS voltage is set at .54. Also the MAF is new. . Not sure what else to check
climate
Haha, No way I am moving whre it is warmer than here in North Fla. Right now it is 88 degrees at 1040 at nite! Car sat up for a few months before it started happening to the point it doesnt like the cold starts at all
How is the fuel pressure and filter.
It was late, i was drinking, i knew i should have checked your signature after i posted. It was funny at the time to me.
2 things come to mind. Dirty injectors and coolant temp switch. Find the sensor, hit it with an infra red thermometer and scan the car to see what it reads for temperature that the ECM sees.
