Opinions on L98 Water Pump
Received 1,401 Likes
I run a Stewart pump, no complaints.
Just to close out the thread: Got the WP in two days. Nice but not that great since I could have driven across town to Summit and picked it up. Any way I installed it last week. What a chore. If you are going to do this take your time and some pictures. I took a camping trip between removal and installation and it was like doing a puzzle. Lots of tubes. used blue sealer on the WP and the bolts and my favorite since 1958, Indian Head, on the hoses. No runs, no drips, no errors and no more coolant on the frame. Thanks to all who gave me input.
Glad to hear all went well. I finished mine a few days ago,went with the Edelbrock. Changed all the coolant hoses and rad hoses while I was in there.
Joel
Joel
Max G’s
Since we both installed the same Edelbrock w/pump about the same time, I've got a question for you. Did you have any problems burping the coolant system with this pump?
Reason I'm asking is it appears there is still air in my system(89 model) and I've burped it about a dozen times. I've NEVER had this problem with this car over the last 20 years of owning it. I've had the coolant system opened up many times doing various repairs,etc. And always after a few times burping it was fine.
Car is not really running hot, just swings in the temp reading from 195* up to 210* and then back in a really short time. Never did this before this pump.
Just curious about your experience with the new pump.
Joel
Joel
Joel
Joel
Joel
Joel
As I recall either the GM manual or the after market Haynes manual said that the system would need burped if the low coolant light came on and to keep adding coolant until the light no longer came on during routine driving. Or it said something pretty close to that. My light never came on. I did not drain the block, just the rad and I don't remember any spill when the pump was removed. Just the lower hose. I refilled and ran it with the cap off the rad and kept adding 50/50 until the rad was full and stayed full. Then fill over flow to hot full line. Should be all there is to it. I checked the rad a couple times in the days that followed. Still full. Maybe I'll drive it some this weekend and I'll watch it closely. I don't think we will be able to tell much until it gets hot again.
The reason I suspect air in the system is the inconsistent temp read out. The car has always had a steady temp rise and fall with the old pump. Plus, now even at a 60-65 mph drive with ambient temps at 70* the temp will rise to about 205*. This never happened before, with the old pump temp would be just above 195*. And this is with a 195* Stant thermostat.
Actually, I don't see any improvement in engine temps with this new pump. And I didn't need any improvement, only changed pump because of a slight weep hole leak. And only bought Edelbrock because of "quality" concerns.
Joel
Joel
Stock pump is fine, my '87 runs about 175-180 on a hot day on the motorway with its thermostatic fan set for 180 and the thermostat is a 160deg one.
Not got the bottle for this 220deg stuff!
Joel
Joel
Forget about "improved cooling", didn't need it with old pump, didn't expect it from new pump. My somewhat concern is with the temp spikes now with this new pump. It's more of an annoyance than a problem really.
Joel
Joel
Do you notice any coolant level drop?
#33
1 Post
Cruise-In X Veteran
I have an Edelbrock pump as well. Quality part, its about 8 years old now. I have a standard rotation version because I changed my belt routing, but basically the same pump.
#34
Joel
Joel
#35
It looks like a good flow of coolant looking into the radiator with the cap off, but I'm not sure how much flow a "wrong" pump would produce?
But like I said earlier, car does not over heat to the point of being harmful. Just spikes up and down and runs warmer than before, both in town and open road at constant cruise.
Joel
Joel
#39
