Oversized Tilt Pins
Oversized Tilt Pins
So about two years ago I removed the driver side tilt pin in my column and replaced it with an enlarged pin from Marc Haibeck in an effort to reduce the column movement. It helped marginally but not as much as I thought. How much more work is it to remove the passenger side tilt pin and replace it as well? I am assuming the steering wheel will have to come off? Is it that even worth my trouble? I want my steering to feel rock solid.
http://www.unbalancedengineering.com/GM/Pins/
Not sure what you paid but the other side is a bit harder and try these.
Yes I realize the other side is a bit harder which is the reason behind this post. just curious how much further I have to dig to replace the passenger side pin.
Alright here is a quick video of what I'm dealing with. It's a small amount, maybe a 1/4". Would you guys go through the hassle of replacing tilt knuckles or the column with this much?
https://youtu.be/a7BuvpZphPM
They had a bit when new.
Quick tilt pin fix: Place the pin on a solid surface like a vice anvil & center punch mark a half dozen spots around the pin. The center punch will raise the metal several thou surrounding each mark. Drive the pin back in = done deal.
Thanks for the Reply's guys!
Alright well I stripped the column down, pulled the pins, dimpled them as church key suggested (awesome idea), put JB weld on the pins, and reinstalled with a brass punch and a hammer. I let it cure 24 hours. Play is still there!!
So either:
1. The 4 bolts further in the column are loose.
2. Something else is worn
3. It's completely normal
4. It may drive me crazy and I go buy another column only to have the same thing?
So either:
Yeah the lower bolts are probably loose. Repaired numerous GM tilt columns in theft vehicles but its been awhile since the last one = memory is fuzzy. Found a video with the procedure.
https://www.youtube.com/watch?v=HsIWG-hRfy0
Gary
So after further reading and playing around I think the play is in the detent pawl and not the pins or the bolts. If I place the tilt wheel all the way at the bottom there is maybe an 1/8" of play. If I move the column up one click there is still about an 1/8" of play. If I move the column up one more click the play is completely gone (or nearly gone you really have to push to feel it). If I move the column up another click the 1/8 play returns. Once the column is all the way to the top there is no more play. So, there are 2 positions on the column where there is NO play. The nice thing is that one of the middle positions is where I like to drive and there is NO play. For now, I am going to leave it. An 1/8" worth of play in the other positions is not enough for me to strip the column down and investigate or replace the column all together. I always find myself trying to make something perfect, only to make it worse or cause another problem. For now its "good enough" for me and I'm not sure a refurbished or low mile column would be any better. Would I like it to be perfect in every tilt position? Yes. But, I honestly never adjust the tilt mechanism once it is set anyway.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
There's a little wiggle against the spring and the pawl. just so long as it doesn't travel in that diagonal downward direction, then both pins are tight (or tight enough). actually when on the road, it seems to tighten up...maybe from the road force on the shaft somehow...
I pulled my column to make it easier to work on...you may have seen my posts in searches..there isn't anything easy about the job.
I worked in company cars at the Arlington factory in 94 and drove many right off the truck. Find something else to obsess over.
And if you really JB welded it you are screwed any ways.
