Voltage drain on my 1996 LT1
I have a problem on my 96 LT1 that has been going on since I got the car last December. If it sits for 2 or 3 days the battery is drained. I have gone through the procedure of removing the fuses one at a time without any results. I have noticed that when I disconnect the neg. battery cable that the drivers side headlight operator motor bumps like it getting momentary voltage. This makes me wonder if the headlight actuator module is the problem.
The part # on the module I have is 16521297. After going online looking for a new module I have found that on the GM parts sites they are listing part #16523917 as the replacement. On one site I went to said that the 16523917 is not a replacement for the 16521297. Can anyone confirm if the two modules are interchangeable?
Do I believe it's your issue? I'd say unlikely and if you just unplugged the module for several days and you still have the draw that creates the loss of power then I'd say you've confirmed that it's NOT. Have you attempted to learn how to do a 'parasitic draw'? Maybe just unplug the LH H/L lift motor.
I did unplug power to the module and voltage draw ceased. I did fail to mention that in my post. I have not tried disconnecting the lift motors. That would be worth a try. If it is one of the motors it will be less expensive than the module.
I did go by the local Chevy dealer this morning and it was confirmed that the 16523917 replaced the 16521297.
Thanks for the help.
You just have to keep looking. I had the same problem 87 vert, chased it for 2 years. One day my wife says hey, your vet is making a funny noise. I run out to it and I can hear a slight hum at the drivers seat. Turns out the sport seat was shorting out some times. I unplugged it and problem solved. Everything is not powered through those fuse blocks. Good luck
When mine was causing issues, if you unhooked the negative battery cable, there was still 19 amps draw if you put an amp meter from the block to the negative post on the block.
Good luck.
To answer your question - YES I believe that the newer 16523917 is a current service number for the 16521297 on your part. Visit a GM DEALER to verify if you like.
