'96 heads/cam/intake & opti, waterpump, etc..
I am doing heads & cam on my '96 A4. I plan on Lloyd Elliott's LE1 package, installing a D36 w/ 3.07 and replacing all the bushings. The shocks were replaced with stock ac delco and I had all the weatherstripping replaced ...but $$$
I hope to get it to my friend's shop next week and start tearing it down and going with what he and Lloyd discuss (valves, springs, roller rockers, Throttle body(?), injectors(?), pcm tune, etc..)
Two things I need to order are an Optispark and a Water pump.
Should I just get stock OEM units? Or get them at an ecklers type place and if so can I get some recommendations.
I know I'll be asking alot of questions over the next couple of months and I appreciate any help from my fellow C4 owners
Unless the opti has an issue I don't know if I would replace it. There are a lot of things that would impact the decision, mileage, condition of old opti, and brand(s) available. New opti's can be a little hit or miss
It has 91K miles on it if it is the original opti and there is oil around it so if it's going to removed, I might as well replace.
I was worried about the "hit or miss opti", I was reading about that a few months ago.
I would imagine there are other places than Ecklers to buy parts without paying the "corvette" markup.Not saying they are bad but do some shopping around at least.
There was a thread here somewhere from SAC CITY or someone about new opti's I believe.When I did mine years ago I went with a MSD and used some locktite on the rotor screws.
I also switched to an electric water pump for a few extra ponies.
Mail order tunes are fine to a point but I would look for a tuner with a chassis dyno so you can at least see things such as a/f ratio.
Start soaking your bottom pully now to save your arm later.
If you do still decide to replace the opti, I implore you to hang onto the stock unit, do NOT throw it away. You may find you need it after all, and if not there are some who will buy it from you just to get that Mitsu sensor.
Where do you guys suggest sourcing a cap and rotor from?
3 things:
1) water pump - $70 Rock auto type place to $239(chromed) Ecklers type....I do not need chromed, but not crap "made in _____"
2) Optispark, praying its just a cap/rotor/cleaning...if not "new old stock" system?
3)Lloyd Elliott LE1 or LE2 package?? Upgrading parts(valves & springs) from LE1 to LE2 are the same cost...$1600 w/ cam...I know the mechanic will be speaking to Lloyd, but I'm curious as to others experience with these packages.
TIA
TIA
Well, as I said I just used the ones that came with the AIP unit and they're working fine. I'm sure there are differences in materials, I've heard good things about the MSD parts but don't have personal experience. If I were buying I'd probably stick with either the MSD or ACDelco stuff just because it's so hard to get to it if you should need to replace it later.
9T3VETTE (01-15-2017)
If your thinking about the msd optI I would just buy a oem no unit, hard to find but they are out there.
As far as the le package if you need to Pass a sniffer test stay with the le1 package, if you don't need to pass the sniffer then go with le2 heads and a 1.5le cam and be happy with 360-370RWHP
vette196 (01-16-2017)
With cam and head porting that come with these packages, won't the OP need to do some tuning? For the 96 model year, that means either Jet DST or the Carputing software and interface. If so, he should be able to set the diagnostic switches to immediately set readiness and not report any problems. That's if the emissions test is a plug-in scan type of test. If his state really still requires an actual sniffer in the tailpipe, then this probably wouldn't pass, but who knows? With cats and air pump and everything tuned properly, it might. But does any state still actually test emissions that way?
I just want a quality part and summit has the ac delco for about $250. I was looking for opinions (especially with our great "quality control" for auto parts) on the $70 Rock auto, Hi-flow Tuff water pump $165 or Ecklers ($200+).
I'm just going off of research, I noticed if I add to the LE1 package (Valves and better springs) it brings the cost to what the LE2 package had, and with a cam(not too wild), it said stock gears and TC are OK.
TIA
I plan on sending out the PCM to PCM4less or who Lloyd might recommend to deal with those issues as well as different rear ratio, cam, etc...
Then I know for certain that the plug-in scan can be passed using the Jet DST package and setting the appropriate diagnostic switches to "Type D- no reporting." For the visual, they'll need to see cats and probably an air pump. FWIW, a 3" dual exhaust with good cats is not too restrictive.
vette196 (01-18-2017)
I went with LE2 on my 1994, last year. Lloyd is very helpful and will guide you regarding injectors, etc. AIR, EGR delete, no CATS, TPIS headers, etc. I did PCM for less for the tune, which is fine (have them reprogram your coolant fans, too). Would like to find a good dyno tuner near here. I went with a 3000 lock up converter on my 3.07 Dana 36. Night and day difference in this car. My next project is going to 3.73 diff. There is no surge with the 3000 converter, until it shifts into overdrive which it keeps doing even around town. For now I just don't put it in "drive." Not a deal breaker, just an FYI.
I was anxious, then just went for it. Don't look back. You won't be sorry.
